TRANSLATOR .XML FILES
Tom Krowka
Where do they go. I've looked in dxf/dwg translators in application data/graphisoft/ but the folder is empty. I do have translators that come up in the dialogue box, but where are they. I need to copy one to a different machine.
I've checked the file types in the folder options/view menu, and the .xml folders should show up, but the folder is empty.
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
The location is readable in the DXF-DWG Translation Setup dialog under 'Info'.
(On OS X, user translators are at ~/Library/Application Support/Graphisoft/DXF-DWG Translators.)
HTH,
James Murray
Archicad 29 • Rill Architects • macOS • OnLand.info
Ben Odonnell
Hi Tom,
You will find them here on the PC C:\Documents and Settings\USER\Graphisoft\DXF-DWG Translators
HTH.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
