TRIMMING WALLS TO STAIRS??
Hey Everyone!
I am currently working on a building section, everything looks great, except that I can not trim a wall to the underside of my stairs. Can I do this? Or can I draw the wall in 2D? Or, the last thing I could think of to do was cover it with a fill in the section, and send it to front, but I am not sure if I can do this. Please Help!!
Thanks,
Michelle Cutrara
Try using an SEO, if you go to the help menu, type "stair wall" and select the first choice of solid operation example it will walk you through the whole process.
Hope that helps.
