Tapered beam
I have to make beams with variable section as you can see in attached image.
How can I do? I tried with objects: inclined beams 15, precast concreate beams but nothing...all that I was able to obtain is a tapered beam but in the other direction!!!!
Thank you
Nicola
10 Replies 10
David Maudlin
Nicola wrote:
now if i want to change the fill (not only section fill) how can I do it? I'd like to see it (timber fill) in elevations or parallel section...
Before following Andro55's instructions, set the material and fill of the slab to the desired attributes. You can save the slab as a library part with the same name in the same location, overwriting and replacing the previous object.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
