Teamwork Setup
How do I start a teamwork project? I keep reading in the books and manuals about sharing the project....HOW do you do that? I see the teamwork toolbar but its all greyed out.
Is it possibly that it is a trial version and you cant use teamwork without the full working version? We are planning to buy it but I am trying to set up for a project until we do buy it.
Just wanted to make sure it wasn't a trail version issue.
vfrontiers
You are correct, NO Teamwork in trial version.
The way it works is after creating a SOLO project (.pln) you have to SHARE THIS PROJECT... then team members can SIGN IN to this and create their own unique LOCAL COPIES. Changes are SENT and RECEIVED to the HOST file and in so doing, update that local copy.
Teammates can continue to work with the LOCAL copy until they either want to CHANGE THE WORKSPACE (add or delete Layers, Stories, etc) or SIGN OUT.
There's the nutshell version. Plenty of idiosyncrasies, but that's beyond the scope of this answer.
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
ok thanks, thats what I figured but wanted to make sure.
