‎2006-04-06 03:38 PM
‎2006-04-06 04:06 PM
1Adam12 wrote:I went through this about a year ago on a file of comparable size. I was working on the project as well, and these seemed to work.
I'm curious about other's experiences with Teamwork. I'm on the IT side of things and am supporting a group of ArchiCad users using Teamwork with a file in the 150MB range for a large project. The endusers are using high end dual cpu XP workstations, minimum 2GB RAM, gigabit ethernet, local, optimized libraries, latest ArchiCAD SP's, and are seeing 10-15 minutes minimum for Send-Receive to complete. It's quite a thorn in my side.
What do you see in practical use? What are your best practices with Teamwork?
‎2006-04-06 04:54 PM
‎2006-04-06 04:57 PM
r wrote:We have the same problem on Apple OS X / OS X Server. For 150 MB file, it takes about 10 to 15 minutes to Send & Receive. I think the S&R/Teamwork function just slows down as the files get bigger. I mapped out the process once, watching the scratch files build, then the originals get moved to the Backups/ folder, then the scratch file get renamed. S&R with a Workspace change added one more file scratch file recreation, if I remember right, so you were essentially moving three 150 MB files over the network to complete the process.
hmmm we have this problem alot....my gut feeling this is an xp issue and could be related the lck/scratch files created during the process...quite often I have to purge the network of left over scratch files....in addition...the scratch file is not associated to anything and we all know how possessive bill gates can be
‎2006-04-06 06:01 PM
‎2006-04-06 06:11 PM
‎2006-04-06 07:19 PM
‎2006-04-07 06:00 PM
‎2006-04-08 06:20 PM
‎2006-04-08 06:55 PM
LewBishop wrote:Lew,
It appears that we are all experiencing similar slow down conditions.
