2005-08-27 03:08 AM
2005-08-29 04:17 PM
Erika wrote:Yes the strategy change according to the specificity of the phases of design and of the proximity of the deadline…
I was also wondering, do you find that your strategy changes as projects progress from the beginning design stages through construction documents? Granted the distinction between these are now blurred since Archicad.
2005-08-29 04:19 PM
Erika wrote:Our office keeps jobs single-user as long as possible, since Teamworking is pretty simple to set up. It's often two people in the beginning, with 5 or 6 later on. When it's only 2, they kind of handle their own workflow. Once the main production crew comes in, I come in with my rule book and make sure people are not changing workspace 10 times a day....
Tom, Frédéric et al,
Thank you for your help. I was also wondering, do you find that your strategy changes as projects progress from the beginning design stages through construction documents? Granted the distinction between these are now blurred since Archicad.
2005-08-29 07:29 PM
2005-08-29 07:51 PM
laszlonagy wrote:A few things to keep in mind about Teamwork and signing out:
We have not actually started using Teamwork, because we are just upgrading our office to AC9.
What I will probably suggest to my fellow collegues is to divide by either occupying various layer, or by occupying various Section/Elevation/Detail Windows.
With the first, one guy can put all the annotation to its layer, another one can create dimensions etc.
With thel latter, we can say I am working on the Floor Plan, you are doing the elevations. If I changed something in the model, I send my changes and you receive them.
Of course we try to keep the projects as one-person jobs as long as possible.
2005-08-29 08:07 PM
TomWaltz wrote:Thanks for the info. I am sure it will be useful for others as well as for me.
- If you sign out a floor and layers, you own the 3D elements. You can edit these 3D elements in any view, including sections you do not own.
- If you sign out a section, you only control the marker, and the annotation in the section, regardless of layer.
- If you sign out a detail, you control the entire content of the detail window, regardless of layers.
2005-08-29 08:11 PM
do not try to modify elements, only add 2D stuff to the model.good for you!!
2005-08-30 04:48 PM
2005-08-30 04:58 PM
Erika wrote:Erica, funny you should ask.... I have seriously thought about cutting out the company-specific parts and trying to publish it once I am done.... maybe through Objects Online.
Thank you everyone for all your help. Your guidance is just what I was looking for.
Tom, when are you publishing your Rules Book?
Does it come with thumbscrews?
2005-08-30 05:08 PM
TomWaltz wrote:
Also included will be a mouse driver for delivering high-voltage shocks to people who do not comply.
2005-08-30 05:46 PM
TomWaltz wrote:I hope you do. A proper actual-experience guide for teamwork is much needed.
