Teamwork viewsets
We've been having trouble in teamwork with creating viewsets when signed in as a teammate. Is it only the Team Leader that can do this or are we missing something?
5 Replies 5
David Larrew
Rule-of-thumb: Anything that relates to project settings or output (Publisher) should be, if not required to be, done by the Team Leader.
David Larrew, AIA, GDLA, GSRC
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
__archiben
amanda
viewsets are a weird breed: they are 'owned' by teammates in the same way that a teammate can 'own' and edit elements from the project file, however there is no way to transfer this ownership so that another teammate can sign-in to them. i.e. you cannot signout of viewsets like you can for the rest of the project.
this means that although any teammate can create viewsets, they, and only they, are then allowed to edit them or 'share' them to the rest of the teammates for their use or for use in plotmaker.
this is another of those functions that works perfectly in a solo project, but goes bottom-up in the teamwork environment! the way we work around this is have a virtual teammate signed in continuously as teamleader. if anybody needs to create, manage or edit viewsets they simply open up that particular teamwork draft to make the changes - this ensures that the views are always owned by the same 'person'. if a normal teammate leaves the project, their viewsets won't be lost from editing, etc.
(btw - this virtual teamleader also manages the attributes and dwg x-ref management: see my topic here)
another thing to note: if a solo project is shared to a teamwork file with viewsets already present, the views will still appear to be owned by nobody in the teamwork file: you see the little teamwork heads icon if it's not in your 'workspace'. however the teamleader is still able to edit and manage these viewsets.
confused? so are we all! i think that there has been a wish somewhere along the line for GS to sort out viewset management...
HTH
~/archiben
b e n _ f r o s t
Ben,
Thanks for your helpful response. You said that teammates can create viewsets and then "share" them. How do they do this? I think this is what we need to do, but it seems like the teammates weren't able to even create a viewset from what they told me.
I'm still pretty unclear on how we have someone sign in as a virtual Team Leader. Can you explain this for me?
We're all new at this and having to constantly have the person signed in as TeamLeader take care of creating viewsets as they are ready is super inefficient.
Thanks so much for your help.
Amanda
__archiben
amanda
okay - a bit more detail:
see the attached screenshot image - it shows all of the viewset management controls from the drop-down box at the top of the 'View Editor'.
you can see all of the viewsets available at the bottom. the ones with the little head icons are viewsets owned by another team member that are 'shared' to the team for viewing. at the bottom is a set that i've created for my own use in navigating the project - i've shared it for others to use if they wish. it's denoted by the hand icon - this means that i own it and have shared it. the final viewset in the list is owned by me, but not shared.
other teammates can also create and use their own viewsets, and unless they've shared them they won't show up in my list.
(by the way - don't set your viewsets up like this. it's a system that we have in place for a variety of reasons, but it's not the most efficient or 'best practice': look at the defaults in a 'new and reset' document to see how GS intend them to be used! )
let's say that you have a project with various team members: "Ben Frost", "Amanda Mason" and "Djordje Grujic". each of the teammates here can sign into a project as team leader if nobody else already has this status. so "Amanda Mason" signs in as team leader and creates a viewset for all general arrangement drawings. "Amanda Mason" then shares this viewset and all other teammates now see this viewset in their view editor, but cannot edit, redefine, delete views, etc.
this viewset is owned by "Amanda Mason" not the team leader - even though "Amanda Mason" was team leader when she created the viewset. only somebody signed into the project as "Amanda Mason" can edit, add to, delete, etc anything associated with these views.
and this is where the virtual team leader comes in:
when the very first person signs into a team project type in a generic name at the very first dialogue screen, rather than your own. we use "File Manager", but it could equally be "Team Leader" or "Project Architect" or "Mickey Mouse". at the same time choose the 'team leader' status.
(aside - if you are using x-ref management also sign into all stories and all layers already associated with x-ref drawings at this point. see the link in my post up there)
so when you're finished, save this teamwork draft file on the server (or somewhere the team has access to) as "ProjectManagement.plc" or similar, and then repeat the sign-in process with your own name and everything that you need to work on.
any project management should then be done through this team leader draft on the server - you can limit who can and can't open it by carefully distributing the team leader password. all new viewsets and view editting should be done by opening this draft and sending changes. all attribute management can also be done in this file (layers, composites, etc, etc) without the need for continuous signing in and out of teammates to modify small settings.
it ensures that anybody (with teamleader password) can manage the viewsets without having to pester the person who first created the viewset, etc.
another thing to note, viewsets are stored (along with most of the project) with ID numbers and not names - it's this number that allows plotmaker to keep track of the view if you modify naming conventions, etc.
hope that this makes sense and you'll find it useful. it's essentially a workaround for the poor project management abilities in the teamwork environment and something i really hope graphisoft are working to rectify!
~/archiben
b e n _ f r o s t
This is how our office does it:
To better manage quickviews when using Teamwork, follow these procedures:
1) Before sharing a Solo project, create a View Set in the NavigatorWindow and name it "Publisher Set". (You can have this set already defined in a template file.)
2) Share the project. Since the "Publisher Set" view set existed prior to the creation of the teamwork project, it is automatically visible and usable to all users who now sign-in. However, to create or edit quickviews in this view set, a user must be signed in as Team Leader. Exclusive access is not required.
3) Teammate users should create and share view sets in which their quickviews can be placed. They should name the viewset the same as their sign-in name.
4) When a teammate is ready to link new quickviews into a layout book in Plotmaker, they should sign in to Archicad as Team Leader and copy the proper quickviews from the teammate view set to the "Publisher Set". This will make management of the Plotmaker drawings easier to follow. Use the "View Editor" mode of the NavigatorWindow to copy quickviews across view sets.
5) In the Plotmaker layout book, only import quickviews from the "Publisher Set". Avoid linking to a teammate named set directly, as the views in these sets may change or be deleted when they are copied to the "Publisher Set".
