Unfortunately the views in the View Map will have to be re-created.
There is no way to transfer them from one file to another.
Except via "Save As" which defeats the purpose of starting from a new clean template.
Maybe if you have a new template with all the attributes you want, and an old file that has the views you want you could try "Save As" with the view file and delete ALL of the attributes as well as the favourites, MVO settings, Graphic Overrides, Renovation Filters, etc., so you have as clean a file as you can get with just the views you want.
Then import all of those settings from the template you are working on.
Personally I would just recreate the views.
Make sure you also update your layout pages if you have pre-placed those views on the layouts.
