‎2005-09-16 06:57 PM
‎2005-09-22 12:58 AM
Repeat after me: "The Label Tool is not for placing text. It is for placing Label Objects"Wow Tom - with all due respect mate - I couldn't disgree with you more on this one. The label tool is fantastic for placing text. They become one element, you can mirror them predictably, you can make favorites of them (!!). In fact this is what an
It excels at placing objects which call out element ID's. It's not a text tool, and behaves terribly if you try to use it as one.
You will get much better results if you place your text, then use a polyline with an arrowhead on the end to draw a leader.
I blame Graphisoft, since their icon is VERY misleading
‎2005-09-22 01:31 AM
Link wrote:unfortunately link i'm coming down on the side of the 'don't even think about using labels for placing text'. it all comes down to usability (again) . . . the label tool makes such hard work of anything such that placing a couple of lines and a text block gives far more positioning and editing flexibility.
‎2005-09-22 02:11 AM
i guess we mac users have been treated to the deluxe usability model for so long that we won't lower ourselves to inferior tools anymore . . .I guess so mate - maybe you should give them another try?
‎2005-09-22 02:30 AM
Link wrote:Link,
I guess so mate - maybe you should give them another try?Make a few favorites with predefined text, (be sure to uncheck the Fix Angle until GS fixes the bug) and label away.Cheers,
Link.
‎2005-09-22 02:38 AM
Link wrote:"adjust" . . . or lack thereof . . .
What's the problem?
‎2005-09-22 02:40 AM
‎2005-09-22 02:51 AM
1) Lack of arrow control - The arrows either come off the very corner of the text block or the very center. Neither coincides with my office's graphic standard.Sometimes you just gotta relax the standards mate!
2) Weird bug where the text and arrow move apart from each other. The arrow moves further upward, and looks like it is pointing to another note.
3) Lack of Search & Replace. It's so nice to find all the notes you placed '5/8" Gypsum Sheating' and change it to "3/4" Plywood", even though it's in a random collection of notes that are not all the same.Search & Replace works with labels too.
4) It's SO cumbersome to change just a couple words in each of a dozen Labels compared to the Text Tool.That's what favorites are for. Select the label in you want to change and double click your favorite. (Just like you do with all your favoriites right?
"adjust" . . . or lack thereof . . .Adjusting labels works
can i ask how you organise the naming of your label favourites when you have several hundred of them? how can it be quicker to find a favourite as opposed to dragging a copy of an existing instance?Very carefully mate!
‎2005-09-22 03:13 AM
Link wrote:annotation often has to be tweaked to fit a particular place on a drawing. part of that also involves abbreviations and grammar alterations without changing the meaning of the particular note. without knowing where that note has got to fit, creating every single instance of that favourite is impossible.Tom wrote:That's what favorites are for. Select the label in you want to change and double click your favorite. (Just like you do with all your favoriites right?
4) It's SO cumbersome to change just a couple words in each of a dozen Labels compared to the Text Tool.)
Link wrote:select leader line > Edit > Adjust > click line/edge you want it to adjust to. (try doing it with more than one leader line) . . . doesn't work with labels - although to the label tool's credit, it does align the text block.Ben wrote:Adjusting labels works
"adjust" . . . or lack thereof . . .beautifully!![]()
‎2005-09-22 03:22 AM
without knowing where that note has got to fit, creating every single instance of that favourite is impossible.You can always stretch the label text to any size block you want right? I don't see how this is any harder than regular text.
select leader line > Edit > Adjust > click line/edge you want it to adjust to. (try doing it with more than one leader line) . . . doesn't work with labelsI must be working miracles in this hotel room, because all my labels are adjusting just fine.
‎2005-09-22 03:32 AM
