Text block justification strange when rotated
I have a problem while working in AC9 which I did not have when working in the 8.1 environ. If I have a text block that is center aligned and I rotate it 90 degrees, it appears on screen as being right justified, which in turn causes the label to be misaligned from where it really sits on the plan... The box itself and the selection nodes appear correct, but the contents of the box are misaligned. Any suggestions? Thx in advance
BTW I am running AC9 and OS 10.2.8 on a dual g4/1gig and not entirely sure of the card
Djordje
Include this in your signature and get the info on the card, as this seems to be the problem.
OS 10.3 would probably help, better Maccers than myself should say!
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
We had a client with the same problem. The text worked fine on the macs with OS 10.3 but they had the same problem on machines with 10.2.8
