2004-07-01 08:56 PM
2010-11-30 09:00 AM
SteveC0013 wrote:This changed a while ago. Perhaps around 9 or 10. As I recall it was to maintain consistency on both Mac and Windows since Windows does not typically distinguish between return and enter. It is a pain though. I miss the functionality.
Label tool Enter/Return changed in AC14...
I'm using a MAC so Alpha is Return and Numeric is Enter. In 13 and previous versions (I think) Return was carriage return and Enter entered the command or closed the window.... Now in AC14 they both are carriage return.... Very annoying.
Is there a way to fix this?
2010-11-30 11:54 AM
Matthew wrote:Having been a DOS/Windows user from the start, I never even
2010-11-30 02:01 PM
SteveC0013 wrote:Steve:
2010-11-30 03:04 PM
Matthew wrote:I have 13 and 14 open now. The Enter key works as I expect it to in 13 but not in 14. I haven't checked earlier version but I may later because I'm curious...
2010-11-30 03:07 PM
David wrote:Thanks for this.... I'm annoyed that I have to add a key but at least I don't have to use the mouse...SteveC0013 wrote:Steve:
Hold down the Command key when hitting Return or Enter to exit editing mode from the Label or Text tools.
2010-11-30 03:24 PM
SteveC0013 wrote:Strange. Perhaps it changed back and I hadn't noticed. I'll have to check.Matthew wrote:I have 13 and 14 open now. The Enter key works as I expect it to in 13 but not in 14. I haven't checked earlier version but I may later because I'm curious...
I did figure out that in 14 Enter does work as I expect it to unless the curser is in the text window. If the text window is not active the the Enter key works as the command enter closing the window....When the cursor is not in the text field both return and enter operate as the default OK to close the dialog. It is only during actual text editing (where you may want a linefeed/carriage return) that the distinction exists.
2010-11-30 04:29 PM
