Textured wall profiles /grating for solar screens
I am working in ArchiCAD 13 on a project with a substantial solar screen. We are spec'ing welded bar grating for this screen and I need to have it represented in it's proper depth to look right-- i.e. a big part of the effect is that it appears more opaque or transparent depending on the angle of view.
I really don't want to have to draw every single bar of the grating in order to make this work. And it doesn't work just to create a custom material, as that would not reflect the change in opacity relating to angle of view.
Does anyone have any tip for this?
David Maudlin
moritz391:
Take a look at the object Grid Vertical 15. But be careful, the polygon count can get very high, slowing down model generation.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thank you for the response David.
Signature modified!
So for a stupid question--where do I find the Grid Vertical object? I have searched online and in my libraries, but am coming up empty.
-Steven
Srinivas
I believe David is mentioning about "Grid Vertical 13" object found under "ArchiCAD Library 13 > Special Construction 13> Basic Shapes 13"
ArchiCAD Services
ArchiCAD since v9 to latest
iMac, Windows 10
