2007-03-09 10:58 PM - last edited on 2023-05-23 03:20 PM by Rubia Torres
2007-03-10 10:07 AM
2007-03-10 07:50 PM
2007-03-11 05:05 PM
2007-03-11 06:42 PM
Matthew wrote:This intrigued me and I did a quick web search. Is this similar to iClip? Would you recommend ScrapIt Pro over iClip? These look like great utilities that I have not taken advantage of. Could you elaborate a little on how you use ScrapIt Pro in your detail organization and placement? Do you use this in place of pre-setting up independent details or just a means to get the details into the pre set placeholders? Thanks for your advice in this area.
I assume that your client is on Windows (as you are) but if they are using Macs there is a great little shareware program called ScrapIt Pro which I have been using and recommending since about 1990 (back then it even had a check box for "ArchiCAD Support"!!!).
2007-03-11 07:18 PM
