2012-04-13
08:54 PM
- last edited on
2023-05-23
02:42 PM
by
Rubia Torres
2015-11-16 05:23 PM
2015-11-17 01:56 PM
Benjaminmeyer wrote:Switch Geometry Method. Go to Work Environment > Shortcut Schemes > Keyboard Shortcuts, List: All commands by theme, look in folder 11 Actions.
or better, what the command's called so I can give it the shortcut I want?
2016-05-26 05:55 PM
2016-05-26 11:19 PM
Fez1974 wrote:jcrarch wrote:Hi Jcrach, this is exactly what I'm after as I find it a pain to keep reaching across to press the delete button when I'm doing lots of dimensioning. How ever I cannot get the cut command to work. Is it the cut as in 'ctl x'
Here's a shortcut I like to use: When my left hand is on the keys & my right hand is on the mouse I don't use the DELETE key on the right hand side of my keyboard. Instead, I use the CUT command with a keyboard shortcut that is on the left hand side of my keyboard. Slightly unconventional, but that's what I do.
2016-05-26 11:21 PM
Benjaminmeyer wrote:It's the letter G.
Hi all,
I can't find the shortcut method to toggle between anchor points while placing a door or window. In older versions of AC, this was easy. Now, I can't even find the menu it's in so I can configure one.
Does someone know the standard one? or better, what the command's called so I can give it the shortcut I want?
2017-01-26 11:23 AM
2017-01-26 11:39 AM
2018-05-29 01:44 PM
2018-05-30 02:53 AM
NoHands wrote:You should find that the '+' and '-' keys do this.
Hi everyone
/I was looking for a keyboard zoom in/out shortcut as I'm a quadriplegic and I can't use a scroll wheel
thx
Shane
2018-05-30 05:37 AM
