2010-03-1504:58 PM - last edited on 2023-05-3001:52 PM by Rubia Torres
2010-03-1504:58 PM
I have been getting into some trouble with the true line weight feature.
I usually find it disorienting to work with the true line weights on. It is difficult to be absolute about where I am making marks and marring nodes. Some times the true line weight does not transpose into the PDF. documents when I have the feature turned off and I publish a document.
I find it odd that that would even happen, but does any one know how to avoid this problem, as I am constantly forgetting to turn the feature back on.
(Keeping in mind that I need to have it turned off to work)
I might just have to risk having mistakes if this persists!
What version of AC are you using? True line weight is a display option, and should not effect output. You may have the "Hairline" box checked in the Print dialog.
MacBook Pro Apple M2 Max, 96 GB of RAM AC27 US (5003) on Mac OS Ventura 13.6.2 Started on AC4.0 in 91/92/93; full-time user since AC8.1 in 2004
