Brett Brown
Tile Views
I did a search on Tile Views in here and AC help,nothing. Can it be done in AC?
2 Replies 2
Link
If you're referring to tiling windows, then yes you can. Just select the Restore option in the top right corner of the window.
You can only have one floor plan window open at once and one 3D window open at once.
In the More Options... of your Work Environment, you'll need to check 'prefer to open in a new window'.
Link.
Brett Brown
Thanks Link, Yes windows, I was hoping it to work like Chief Architect,Revit and others. Would be far more user friendly like the opposition obviously thinks.
