Tilt Column
Can anyone help me out to draw a tilt column as Image Shows?
best and best thanks!!!!!
Richard
5 Replies 5
Do it with Morph tool...
Draw shape with FILL TOOL then use magic tool to trace shape with MORPH,
Extrude Morph to needed size, open dialog box, go to Tags and categories
and assign properties that you need. (structural function, position, Element classification etc)
So you will have Morph object which will act like column....It will be represented in elevations, plans, 3D just fine !
hope this helps
so no way to draw it but only way is drawing by Morph tool?
best,
richard
Umm... yeah pretty much. There is another way as far as I know... a very dumb way, I tried it before.
Put some invisible elements that intersect the column so that after performing solid element operations you get the shape you want. But as I said, this isn't a particularly efficient way to do this.
Can't you make it with complex profile?
Yep, complex Profile is the way to go.
Nando Mogollon
Director @ BuilDigital
[email protected]
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
