Toolbox problem
TomWaltz
I've seen this a few times in AC9 and it continues in 10. I'm hoping some who's better with the Work Environment might have an answer.
When using a custom Toolbox in Archicad, sometimes the Toolbox goes off the bottom of the monitor, making it impossible to grab the lower-right resize corner. (Apple, obviously).
Is there some other way to grab the corner to make the box shorter? I really don't want a full-height toolbar!
Tom Waltz
16 REPLIES 16
I haven't seen this particular behavior. (I assume that it is a case of the toolbar spontaneously changing and not that you have it set that way on your Cinema Display.)
I have had my toolbar "fatten up" spontaneously from my usual single column of tools to the three column style in your screen shot, but it stays its original height. (This only seems to happen after an error in the 2D Full View or 3D View of the library part editor.) I usually just stretch it back, but it also works to reapply the work environment.
TomWaltz
Right, The Toolbox opens that way when turned on from the "Windows > Floating Palettes...." menu. Since there is no resize corner available, I cannot get to the width or the height.
I ended up using a different Palette Scheme then modifying it back to the way I wanted. Kind of a pain, but at least it works.
Tom Waltz
That's the only way. I switched to a two-column toolbox, partly to get away from that problem.
James Murray
Archicad 27 • Rill Architects • macOS • OnLand.info
Link
I haven't had access to a mac for a while now, but are you able to double click on the top of the Toolbox (where it says Toolbox), and have it return to it's original position?
This can be done on a PC to switch the position of the palette from docked to non-docked. I was just wondering (even though palettes don't dock the same way) if you could use the same method on a mac to at least solve the last part of the problem?
Link.
Dwight
Then there's this OTHER toolbar that is tinier and gives no grief.
Dwight Atkinson
Dwight
enabled via:
Dwight Atkinson
I don't know why, but that one seems a little creepy to me. Maybe I should give it another go.
Dwight
Why NOT be modern and look at all of those extra graphic toolbars/command grafix?
Dwight Atkinson
Or I could go deconstuctivist and make a separate floating toolbar for each tool.
