2011-12-06 05:41 PM - last edited on 2023-05-25 05:42 PM by Rubia Torres
2011-12-06 06:29 PM
2011-12-06 06:52 PM
"Jeffrey" wrote:
There are a garden objects in the standard library. Most of what you see here is the hedge element and the tree 3D with different materials applied. You can get them to look better more realistic if you want by using textures with transparency as well.
2011-12-06 07:31 PM
2011-12-13 10:51 PM
2011-12-22 06:22 PM
Jeffrey wrote:I think the original author was Lazzario so he probably remembers where he saved it but i've attached the JPEG anyway.
The grass is a mesh with a grass texture applied and the stone path is a combination of slabs and objects subtracted from the mesh as they are all flat. If the walkway needs to follow the contour of the site you would use the mesh tool.
There is a tutorial kicking around about using the mesh and SEO, but I am not sure where I saw it, and it is more specific to creating the site with a walkway that follows the contour. You achieve the look of grass or stone by applying a texture to the material you are using. Sorry I misunderstood what you were trying to achieve.
2011-12-29 04:19 PM
2011-12-29 10:43 PM
2011-12-30 04:34 AM
2011-12-31 05:07 AM
