Totally Bizarre SEO Behavior
Laura Yanoviak
AC14 -- There are a number of Elements in which I cannot cancel the SEO's. When I delete and re-recreate these Elements the SEO's are still affecting the NEW Elements. When I delete and recreate the SEO's, the NEW SEO's are affecting the NEW Elements.
I am in Teamwork -- I am on a PC while other are on Mac's. I have saved the SEO's and Elements in question as a MOD and am experiencing the same behavior outside of Teamwork.
I have not yet tried to see if the same problem exists on the Mac's.
Laura Yanoviak
UPDATE: Same bizarre behavior on the Mac. I cannot get rid of these SEO's!
hi Laura,
what type of elements are you using as the operator/target?
can you post some 3d images of just the target/operators, maybe with operators layer set to wireframe?
