Trace command opens but will not allow a selection?
I have used the trace command before and had no problem. Now on a new project the Trace command opens but will not allow a selection. All I want to do is have my first floor show below my second floor. I have done this before and had no problem. The only difference is I installed the most recent hotfix. A-11 is current.
1 REPLY 1
So embarrassing. You have to click trace to get it to work. maybe we could look at reducing the number of clicks required? It is very fast, I guess I just forgot how it worked.
