‎2009-11-26 07:54 PM
‎2009-11-26 08:21 PM
‎2009-11-26 11:41 PM
‎2009-11-27 11:44 AM
‎2009-11-27 06:29 PM
‎2009-11-27 06:41 PM
‎2009-11-27 07:47 PM
‎2009-11-27 07:55 PM
‎2009-11-27 10:08 PM
‎2009-11-27 10:58 PM
NStocks wrote:You can draw additional line-work into sections if you wish. I usually do this in elevations, adding thicker lines where I want to add some relief or depth to the drawing.
I have generated this section ( attached ) from a 3D model ( which I though was the correct procedure or creating sections ). I've taken it to my Tutor and she's moaning because it's not ' clean ' enough i.e there are a few lines that end up ' no where ' How can I trace this so that it follows the same shape but allows me to keep all edged joined... I could change the section but the problem would still be there.
