2013-02-28 06:20 AM
2013-02-28 06:28 AM
2013-10-26 11:51 AM
2013-10-27 10:02 PM
compu wrote:This has been a long standing frustration of mine. I've reported it to Graphisoft Tech Support but couldn't quite put my finger on what caused it. Thanks to your post compu I now finally know what causes it so I can try to avoid it in the future!
On the plan, do a little zoom in/out, then just "before" zoom in/out refresh is finished, press M to start measure function... Well, at the time you quit measuring, you'll see that tracker is now turned off!
2013-10-28 01:58 AM
compu wrote:Finally an explanation on what turns it off.
another Moderator
2013-10-28 02:27 AM
2014-01-22 02:28 PM
2014-01-24 08:39 PM
compu wrote:That's great that you've figured out what turns the Tracker off! Well done!
2014-01-28 11:00 PM
compu wrote:Hahah just tried it....its going to be a hard habit to break
2014-02-03 09:58 AM
compu wrote:Thanks for posting the steps that are required to replicate this problem. Forwarded this to our dev folks for fixing.
Rather than assigning a shortcut to Show/Hide Tracker (which had been my own solution, too) it would be a better solution to report this bug to Graphisoft to let them fix anyway within a hotfix. It's a boring thing which remains for years and here is how it does happen:
