‎2012-04-13 02:54 PM
‎2012-04-13 03:59 PM
‎2012-04-13 10:33 PM
‎2012-04-16 10:09 AM
‎2012-04-26 03:49 PM
‎2012-04-27 01:33 AM
Keith wrote:Yes it is strange behavior but it is as designed. I believe it's to avoid confusion with the info palette display. When the favorite is selected (highlighted or grey) its settings are displayed in the info palette but otherwise the palette displays the current default tool or selection settings.
Now that I'm using the Favorites palette, I'm wondering if there's a bug in it.
After you select a favorite, the moment you take the mouse away from the palette, the selection disappears. This happens even if you're only going for the pull-down menu (top-right button)
If you keep your nerve, it reappears again (in grey) when you select from the pull-down, and if you double click to insert a favorite in the drawing, the selected favorite appears.
But this is strange behaviour, surely?
(I'm using release 15 now, BTW)
