Trapezoidal Ramp
Is it possible to make a trapezoidal ramp in archicad?
thank you!
4 Replies 4
Erika Epstein
Yes. One way it to use the roof tool which is a sloped slab. In the plan view you can make it wedge shaped as you show.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
You could use a roof if you just need a sloped surface.
If you want an actual RAMP object (via Stair Tool), you can do the following.
1. Draw a Fill on the floor plan around the perimeter of your intended ramp.
2. Draw a line from the starting edge to the ending edge.
3. Select both the fill and line, and go to Design > Create Stair Using Selection
4. Select the Ramp icon from the dialogue showing the different stair configurations.
5. Configure the Ramp's settings via Stairmaker.
Scott Graham, AIA LEED BD+C
Principal | BIM Manager
Muhlenberg Greene Architects, Ltd.
Wyomissing, PA 19610
V6.5-26.0
Thank you very much to both of you!
It was really helpful!
Bob Moore
I've used complex profile to create ramps which can be edited easily.
AC 7 - 29
iMac 27"
Mac OS Sonoma 14.0
3.1 GHz 6-Core Intel Core
32 GB 2667 MHz DDR4
Radeon Pro 575X 4 GB
