Trial Version Missing Features
ghazal_abodiab
Hi all,  I am using Archicad Trial version 26. I know there should be many options for walls and slaps in the composite lists, but I only have less than 5 for each list. Do you have any idea if the trial version is missing features? I used to use Archicad before 2020 and know that more options should appear on these lists.
Additionally, when I change the fill color  it appears without color on the 2D plan
Are these common bugs in Archicad?
Thanks in advance
1 REPLY 1
Those aren't missing features.  There are only a handful of predefined wall and slab composites to give you an idea of what you can do.  Composites are something that you define... and then use.
If a fill appears without color on the 2D plan, then the most likely reason is that the plan is being displayed with a pen set that has a black or gray pen for the colored pen that you chose, or there is a Graphics Override (refer to the online manual) that is redefining the color.
