rgarand
Triangular Louvers-Gable end louver
Does anyone know where I can find a triangular louver in the 8.0 Library? The library has all of these other great shapes...but not triangular. Is there a work around?
TIA
Robert J. Garand
ArchiCAD USA 28-Build 6003 USA FULL and ArchiCAD USA 29-Build 3000 USA FULL
Windows 11 Prof (64 bit) - Intel i9-14900K CPU 3.20 GHz - 64 GB RAM - NVIDIA RTX 5000 Ada Generation
4 Replies 4
David Larrew
Try using the "W Triangle Fix 81" in the "Special Windows 81" folder. Then assign a material to the glass pane that would mimic the louver slats.
If you wanted a challenge, you could make a down and dirty custom window object using Slabs/Walls/Columns and "Save-As" a window object.
David Larrew, AIA, GDLA, GSRC
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
...and roofs, assuming the louvers are angled.
rgarand
The window routine worked just fine for the moment...I will try drawing one from scratch soon and make it parametric.
Thanks for the quick response
Robert J. Garand
Djordje
TIA
Use the Half round, with resolution at 4. It is triangular.
HTH,
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
