Trim and jamb/head surfaces for an empty opening?
Is it possible to add trim to an empty opening so that it can match the adjacent doors and windows? Am I missing that library part?
4 REPLIES 4
Jesse,
You might try carefully checking the parameters of AC 9's
door library to see if there is a parameter
that hides the door panel leaving a jam and trimmed opening.
In an earlier library version this was an option for some doors.
I say carefully because, as I recall, the door part that had this
option hid this option in the parameter list by making the
parameter for "door panel thickness" have the option of making
the thickness=zero which would cause the door panel not to be drawn.
Peter Devlin
Jesse,
I just looked at one of the interior doors in the AC 9 library
and it has the option your looking for in the "Panel" settings
pull out menu item "Empty". Probably any door or window
has this option.
Peter Devlin
__archiben
Peter wrote:
You might try carefully checking the parameters of AC 9's door library to see if there is a parameter that hides the door panel leaving a jam and trimmed opening.
there is. use the same door as the one next to it and switch off the leaf/panel . . .
~/archiben
b e n f r o s t
THANKS!
