Monday
Hello everyone I'm new in arhicad.
I have problem where I can't cut zones above rooftop windows. Roof is recognized as object while triming with option solid element operation, while rooftop windows are not recognized as object. I will attach an image url.
Thank you 😊
Solved! Go to Solution.
yesterday
Don't use SEO to cut the zone but the "Connect to Roof / Shell" command.
13 hours ago
That will be it.
Skylights cut a hole in the roof, so when you use SEO, there is no roof at that hole to cut the zone.
Trimming to a roof uses the roof's trimming body which is not affected by holes made by the skylight.
Tuesday
Please attach images directly in message rather than a url link.
yesterday
13 hours ago
That will be it.
