Trim to roof anomoly
I've got a roof with valleys and when I trim the walls below to the two roofs forming the valley I get this little skinny piece of wall sticking up right through the valley. Anyone else had this problem and know how to fix it?
Rick
22 Replies 22
Peter wrote:
Karl wrote:
Did 'miter' work in earlier versions of AC with dissimilar sloped roofs? Wonder if this is a bug or user error on my part.
Vertical mitre worked in AC10, but not in 11 or 12!
It worked in AC10 with unequal thickness's too.
How do you get the moulding around the edge of your roof like that? Are you using a complex profile somehow?
Djordje
Complex profile beams?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
It's just a section through the default roof composite. No moulding involved!
