Trimming Shells Problem
Botonis
Mentor
There is a problem when trimming shells with other editable contour shells  used to create holes.
The triiming operation is not following the material priorities and the connection looks absolutely wrong.
Check the pictures wharn you see the initial state, the trimming operation and the merge operation which does not create a ole but connects correctly the materials based on the priorities.
This should be fixed sometime...
Botonis Botonakis
Civil Engineer, Enviromental Design MSc., BIM Manager for BS ArhitectsVR
Company or personal website
Archicad 27. Windows 11. Intel Xeon 2699x2,64 GB RAM, Nvidia 3080Ti. 2 Monitors.
0 REPLIES 0
