ngoldie
Trimming Walls to Roof
I'm having trouble with the trim elements to roof shell. Every time I do it the walls still show on outline on top of the roof which then shows up in plan.
See image attached. Is there anyway to trim it so it isn't showing the outline on top of the roof?
Archicad 20
MacBook Pro - laptop
Erwin Edel
You are using priority based connections, which means that those walls/collumns etc have a building material which has a higher priority than your roof currently has.
Either fix this or use Solid Element Operations instead of Trim.
Trimming is the more intelligent option where your walls and collumns would pass through the 'weaker' materials and stop at the 'stronger' core, provided you set this up correctly.
Solid Element Operations as the name implies just defaults to the solid elements (walls, roofs etc all are solids) as a whole to substract, interfere, exclude etc etc
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
ngoldie
Thanks, I will change the priority of the walls, that was it!
Cheers
Naomi
Archicad 20
