Trimming a sphere to a wall
Hello!
How can I trim a sphere to a wall or a shell.
It should look something like shown on the attached image, only without the slab.
Thank you!
1 Solution
Hmooslechner
Some way:
https://youtu.be/-ZOqOipKdjw
Go to post
3 Replies 3
Hmooslechner
Some way:
So you want to cut the shape of the Sphere from the Wall, right?
In that case, you trim the Wall to the Sphere.
Model the Half sphere using the Shell Tool.
Then in 3D, select the Wall, and use the Connect>Trim Selected Elements to Roof/Shell command of the context menu. (Makes sure the Shell is not selected)
Then click the Shell to specify the element to trim the Wall to.
Then click the part of the Wall you want to keep (outside the Shell volume or inside).
Done. Also, make sure the Building Material of the Shell is stronger the the Building Material of the Wall, since the command connects the Wall and the Shell and Priority Based Connections will become effective between their Building Materials.
Thanks a lot!
I was actually looking for what Hmooslechner showed in the video.
And I managed to do it.
But if I had a lot of spheres, and am not able to create morphs for each, I guess I could do it with SEO Upward extrusion, and then for each do the Trim Elements to Roof/Wall, with Trimming body of spheres changed to Editable, as you LaszloNagy suggested in another post of mine.
