Trimming walls or mesh in sections or elevations.
How do I trim Mesh or wall in an angle. I'm trying to trim or reshape a mesh roof or wall in a section mood but it only moves the whole block. Any ideas?
4 Replies 4
You need to edit that in plan or 3d by SEO or by triming to roof
- or switch the section to drwaing mode - but You will loose updating with the model.
Best Regards,
Piotr
Thank you. I still have problems trimming walls in sections. If I create a round roof and a portion of the wall gets outbounds I am unable to to trim that portion. The trim to the roof does nothing.
TomWaltz
Trim to Roof only works in the 3D window, not elevations or sections.
Tom Waltz
Yet another advantage of the SEOs.
