2005-04-27 01:06 PM
2005-04-27 02:49 PM
Is there any way I can create a truss from a spline?I believe AC want's lines or arcs and NOT spline elements when selecting the Create Truss command under the Extra menu ...
2005-04-27 07:52 PM
2005-04-27 09:36 PM
kim_engrob wrote:Included in your online (F1) help system as well as a PDF on the installation CD is a book by David Nicholson-Cole, "Introduction to Object Making". Find section 2.7 of that book, which is also online here:
I have created a "vaulted roof polyarc profile".
Now I need to make a truss in the same shape. I know trussmaker won´t use the spline i used for the roof!!
What do i do? Can anyone help me?
2005-04-28 12:32 AM
kim_engrob wrote:Does it work to "trace" the polyarc with the arc tool such that you have a series of lines and arcs. You might even be able to explode the polyarc and avoid the intermediary step. Truss maker uses center lines to reference from.
Best regards
Kim Engrob, Student Århus DK
