Turning meshes into solid objects
can someone help me... i know how to create meshes but cant work out how to turn the mesh into a solid object... it only appears as a wire frame in the 3D window, and when i followed the instructions for turning a mesh into a roof... i couldnt find a "convert mesh to roof" button under tools
someone please help
11 Replies 11
Djordje
Is the layer that the mesh is on in Wireframe state?
Is the 3D display in wireframe?
Are eny errors reported while generating the 3D?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
no problems reported generating 3D
Dont know about the wireframe stuff but other slabs on the same level appear solid
Dwight
look at the layer dialog for wireframe layer state.
Dwight Atkinson
I'm only a student and only have a little archicad knowledge... so what you said jus went straight over my head
Djordje
Post a screen shot, so that we can know what are you talking about.
Djordje
HP Omen
Dwight
here is the layer dialog.
look down the columns for solid or wireframe setting.
wireframe layer setting help identfy elements used for SEO and other tricks like see thru parts
Dwight Atkinson
im trying to make the area in between the concrete into a grass hill
i have found the layer thing but nothing mentioning solid, wireframe, or SEO
Djordje
There is a problem with your mesh. I suspect the holes might be it.
Try not to cut holes in the shape of the snaking path (road?) but place the mesh a bit lower. If you do need to indent the road in the mesh, use Solid Elements Operations.
Also, download and try ArchiTerra by Cigraph.
Djordje
HP Omen
