Turning on an edge
Is there a way that I can turn a morph in the 3d window through a edge? ( I mean not only in 2d through the vertical edge?
You can rotate a morph in 3D in any direction you want.
You need to establish the rotation plane by choosing a plane perpendicular to the edge you want to rotate around.
If you don't have a plane that is perpendicular then you will have to establish it first.
