Two Urgent Questions
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2009-02-18
08:01 PM
2023-05-23
04:56 PM
Rubia Torres
2009-02-18
08:01 PM
1. Where is the light Object stored in AC 12...? the one for a general light to be used in a 3D model..?
2. Is there a simple Tutorial for the Window Wall...? and must all be done in the in-accurate 3d window...?
3. Do others have a problem shutting down their Power MAC's . ArchiCAD 12 often will not shut down with out using the FORCE QUIT....any recommendations
Thanks, Paul
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-02-18 08:18 PM
2009-02-18
08:18 PM
1. Under Photorendering settings with Lightworks Engine. Use the Sun setting.
2. In GS sitehttp://www.graphisoft.com/products/archicad/ac12/new-features/ Yes, all editing in the 3D
3. No problems. AC takes a little time to shutdown though.
2. In GS site
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
AC28 US/INT -> AC08
another Moderator
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-02-18 11:45 PM
2009-02-18
11:45 PM
You can also edit the curtain walls in section. The tool is a bit tricky to learn since it is quite different from anything else to date. This is supposed to improve in future releases.
3D editing can be just as accurate as working in plan. I do much of my work in 3D now, perhaps most of it.
