Two houses - different ground florr elevation
I have to draw two houses in same project but they have different ground floor elevations. For example, House 2 have ground floor 1,5 meter higher then House 1. As far as I know i could draw them separately and merge one into other house project and then select one house and elevate.
My question is: is there better way to do it? Especially when floors on both houses are not the same heights?
Need explanation/solution for project with two houses:
Example 1: both houses have ground floor slab on same height but height of that story is different on both houses (house 1 = 3m, house 2 = 2.6m)
Example 2: both houses have story height 3m but house 2 have 1.5m higher slab (floor), so house 2 is practically lift up 1.5m cmpare to house 1.
I hope some1 understands what I mean I'm not that good in english.
Anyway, thank you all in advance
Mikey
2 Replies 2
Rakela Raul
mikey.. do a search... several experts already explained this
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
Your Project will consist:
1. Base .pln with 3D terrain on which you insert both .mod files
2. House 1 .pln + .mod
3. House 2 .pln + .mod
