Display malfunction of Graphisoft ID dashboard
Learn more
UTM coordinates
Can someone tell me how do we use UTM coordinates in AC?
I need to georef on site.
I'm a bit confused.
Thank you.
4 Replies 4
Ok, I got it.
Thank you.
Eduardo Rolon
Standard procedure (and common courtesy) when one figures out their own question is to post the answer anyway so that somebody else using search can find it.
share
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
You are right, but since no one responded, I thought that the question was silly. But here it goes.
I had to put this site in UTM coordinates, so after failing some times trying to put the coordinates in a rectangular shape....
1- I put one ref line from the left and gave the W coordinate, pushed down another ref line and gave it the S coordinate, used the coordinate dimension tool to mark the point and did the same for the other 3 points.
Another pic. It's worth a thousand words. 🙂
