Undocumented Improvements in AC15
Link
Here is the beginning of a list of 'minor' fixes in AC15 that I was personally involved in. I hope that others may be able to add other undocumented improvements to it:
1. Mirroring text now mirrors the anchor point.
2. The Help menu search function is no longer case sensitive.
3. Fill Area Text's are transferable via the eyedropper/syringe.
4. Project North now accepts up to 4 decimals (when set in working units).
5. Right click on Layouts and Masters to edit their settings.
6. Module Save Options have a new display setting.
Link.
56 REPLIES 56
Rick Thompson
Link wrote:
If you have say Chair 1 14 in AC14, it should automatically switch to Chair 1 15 when migrated. Link.
It has been working fine with my plans, and I am always opening old pln's… HOWEVER, there is one significant bug if you link those objects to Property Objects that link is gone. So, if you run a list and forget to re-link it to the 15 object, you will have errors. That could be trouble if you run material list and are not careful.
Rick Thompson
Mac Sonoma AC 26
http://www.thompsonplans.com
Mac M2 studio w/ display
direct feedback in the tracker on the length of an arc
and one more for GDL folks...
One can insert the new variable (parameter) not only the end of the list of the variables but before the selected variable.
that's fine!
RandyC
You can now input roof slope in degrees , % slope, or percentage of 12
from INFO box window
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
When a new version comes out I always like to go to the Work Environment Dialog, go to the Command Layout Schemes\Menus page, and set the "All new commands in alphabetical order" in the List field.
That always gives me clues to some hidden new stuff.
It also includes older commands or options which now received a keyboard shortcut (like Offset and Multiple Offset constraints in AC15).
Did you know, new autosave TW-style: superfast and supersafe:
Master wrote:
another one, the Quick Layers toolbar can now be docked!
Thanks for the tip Jeroen
BTW; Love your keynote object, Autonotes as modified for me.
Got a nice compliment from the senior plan checker on 18 page AC-14
permit approval!
So cool!!
lec
Rafal SLEK
One new option about duplicates during embedding library parts:
Best
Rafał
//Archicad since 4.1 version
//MacBook Pro Retina 2019/2.4 GHz/Intel Core i9/32GB RAM/Radeon Pro 5500M 4GB/macOS 13.6
//Razer Intel i9/2.5GHz/32GB/Nvidia RTX 3080/Windows 11 Pro
//ArchiCAD 28/Twinmotion 2024
vfrontiers
Not sure if this is UNDOCUMENTED or if it's even NEW to 15...
In the INDEX settings.. you can now choose SUBSET ID and/or NAME!..
Nice to create heading for the different plans based on your SUBSET organization..
Oh, and the FRAME (around text blocks) Dimension can now be entered without having to turn on frames first...
It's friday and I'm easily amused!
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
Not sure is this new to 15 or not.
Now that the Layout page allowed you to enter the page no and it will bring you straight to that page.
Is quicker than double click on the layout page
