Unexpected 3D view of wall in AC22
The attached picture is the view of a simple wall, door and window.
No matter what I have tried : Document>option views; Layers, MVO overrides, the resulting image is similar to a "wireframe look"
Your suggestions and comments to correct this will be appreciated
Win 10 Home Premium - AMD Phenom IIX6 1090T Processor 3.20 GHZ 8.00 GB RAM 64-bit Opp. Sys NVIDIA Quadro 4000 AC 22, MEP
11 Replies 11
Conrado wrote:
Thanks guys
I turns out that under the 3D styles "trasnparency" transparency was checked-in.
This will only make materials with transparency appear transparent.
So the wall and the door frame must have a materials like glass (or they are being overridden by GO or Reno filter to have a transparent material).
Whereas the window frame does not.
Lingwisyer wrote:
In the original image, the window is not wire-framed, so I am now a bit confused by this "solution"...
This is because the window does not have a material with transparency.
