Unfolding surfaces/objects onto floor plan
Is it possible in Ac to unfold surfaces of more complicated 3d object (i.e. cone) onto the floor plan, to be able to measure it? Or is there any Add on that lets us do it ?
in other words:
http://www.cad-addict.com/2009/05/sketchup-plugins-unfold-your-model.html
I just want to draw a quite big wardrobe (making a 3d model) with lots of different sized shelves. But eventually I'd like to have each element on the floor plan to measure it and then send the drawing to the carpentry. I thought unfold option could do the trick but maybe You have any other ideas?
thanks
10 REPLIES 10
Eduardo Rolon
Had to do something like that sometime ago and what I did was
1. go to the 3D Window
2. selected "Show Selected in 3D" to only show that part
3. used the Look to Perpendicular item to get the view needed
4. save the view as 3D Document and dimension there.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
thanks, I'll try that.
This is a very interesting question!
Really,is there a way to get unfolded flat developments from 3d objects?
I know this is a more specialized fuction and used in software like solidworks and inventor, but it would be a valuable asset if there was a way to have that in AC.
Ejrolon,
It won't work when the object is slanted..it workds only when objects are perpendicular or parallel to the 'floor plan'.
The 'Look to perpendicular' command should give you a view perpendicular to any surface you click on - even if it is not perpendicular/parallel to the floor plane (i.e. a roof plane).
Eduardo Rolon
Works with slanted
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
Perpendicular to Wall
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
Perpendicular to first roof
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
Perpendicular to second roof
AC29 US/INT -> AC08
another Moderator
