2011-11-07
04:32 PM
2023-05-23
04:40 PM
Rubia Torres
2011-11-07 07:56 PM
tlodge wrote:Could it be that the master layout you are using in this particular case contains a drawing?
In the model space all is as it should be. However, once placed on the layout a random unexplained PFC is shown which cannot be selected individually
2011-11-08 09:56 AM
2011-11-08 12:05 PM
2011-11-08 12:34 PM
zeropointreference wrote:As you suggested moved everything in the model space and the ghost PFC moved too. So slowly moved sections until everything was moved away except for the ghost PFC.
You could either start deleting or moving stuff, especially objects of the same type, and switch back to the affected layouts to see if the object has moved. Use the half/half technique to narrow down the culprit object if it's not attached the first objects tried.
2011-11-09 12:50 PM
