Updating Shadows in Elevation View
Stress Co_
I'm studying how eaves & shading devices shadow windows during different times of the day/year in the ELEVATION window. (I don't want to do a 3D sun study ....yet.)
I set my Location, Date and Project North in: Image>3D Projection Settings> More sun
My Elevations are set to: Model Effects: Vectorial sun shadows >
Sun: As in 3D window
After changing the sun's time/day, I go to my elevation, rebuild ...but the shadows do not update.
Do I need to do more than hit "rebuild"?
Marc
Marc Corney, Architect
Red Canoe Architecture, P. A.
12 REPLIES 12
Mark,
You might try pushing alt+command and while holding down these keys
go to the display menu, you will see the option change to
"Rebuild and Regenerate"
Thank you,
Peter Devlin
Stress Co_
Peter:
Thanks for the suggestion, but rebuild/regenerate didn't update the shadows...
marc
Mark,
I just checked in one of our projects.
Shadows were off in the 3D window settings.
I set the S/E settings just as you have them.
I viewed the "linked" S/E window showing shadows,
went to the 3D window changed the sun angle,
went back to the S/E window, did a rebuild and,
the shadows updated.
I don't know what could be wrong.
Have you tried cutting and then pasting back in the section marker ?
Thank you,
Peter Devlin
You may need to adjust the settings of your elevations. Select the marker or elevation line in plan view and then in the toolbox double click the elevation tool to open the settings dialog box. Then look under "Model Effects" and make sure that Sun is set to "As in 3D Window" instead of custom.
Stress Co_
Alex:
All my elevations are set to:"as in 3D window".
Peter:
My initially switch to "as in 3D window" worked like your test. It's after I changed the sun's position a second time that it wouldn't update. Will yours update on a 2nd or 3rd try?
I haven't tried cut/paste yet... but I did create a new elevation.... but it won't update the shadows either.
Marc
Mark,
I tried it with five different sun positions and the S/E window,
after rebuild, updated correctly every time.
Thank you,
Peter Devlin
Mark,
Have you tried the old standby, restarting your computer ?
Honestly, sometimes that fixes weird problems.
Thank you,
Peter Devlin
Stress Co_
Peter:
I tried restarting and .... that didn't do the trick.
The elevation shadows do change when I switch between the "as in 3D window" and "custom" settings.... Found here: Elevation Selections> Model Effects> Vectorial sun shadows > Sun
I'm wondering if I'm setting the sun (sunset ) from the wrong 3D menu.
I'm doing it from here..............3D projection settings ...(see jpg)
Note: the sun changes are common between the"Perspective settings " & "parallel projection" windows.
3D engine is "Open GL"
and Mode is "Shading"
Marc
Mark,
I am at a loss.
Have you tried using the internal engine rather than
the OpenGL engine ?
The only reason I ask this is I am using the internal engine
and I notice you are using the OpenGL engine which is apparently
the only difference between our set-ups.
I can't imagine how this would make any difference, but who knows.
Thanks,
Peter
