Showing results forย
Search instead forย
Did you mean:ย
Search instead forย
Did you mean:ย
Using stairs as SEO operator?
Forgive me if this question is answered elsewhere... I was unable to find it. I am designing a small house, which has a "U-shaped" staircase, and I'd like to trim the top of a wall to the bottom of the stairs, to box in the area under the stairs, I tried doing SEO subtraction, but nothing happened.. is this supposed to work? and if so, what am I doing wrong. If this doesnt work, how can I do this?
cheers,
dan
1 Reply 1
would help if I spelled stairs right when searching the forum... sorry, but I found the answer
http://archicad-talk.graphisoft.com/viewtopic.php?t=6579&start=0&postdays=0&postorder=asc&highlight=...
cheers,
dan
