‎2006-03-18
07:44 PM
‎2023-05-25
06:00 PM
Rubia Torres
‎2006-03-18 10:01 PM
rjbecs wrote:The easy way is to change the "Background Fill" to pen 0. This will make the fill transparent so you only see the fill pattern.
Hi there,
When using the fill tool to create a floor pattern on top of a floor slab, for exmaple a wooden/tiled floor... can someone explain why it just takes over the whole drawing? Everything in the room where the place the fill on the floor is covered by the fill.... how do I make the fill less overpowering and also not show above furniture objects? Also is there any way to make the fill pen line finer so it is less noticeable on the drawing?
Thanks in advance
‎2006-03-19 12:30 AM
rjbecs wrote:Send to Back (Shift F5).
rjbecs wrote:Change the Pen to a Pen that is Finer. See Attachment. If the drawing is to be printed or plotted using PlotMaker (recommended), than the Pen Can also be Modified there as well.
.... Also is there any way to make the fill pen line finer so it is less noticeable on the drawing?
Thanks in advance
‎2006-03-19 01:12 AM
‎2006-03-19 12:14 PM
‎2006-03-19 01:25 PM
I am guessing that the problem is that you have your display options set to show all fills with transparent backgrounds so that the fills are not showing 'over' the furniture but 'through' it.Hmm this could be it, as I've not changed any other settings, this is the first time I've even used the program properly. I don't know how to change the display options for this.... can you help?
‎2006-03-19 05:49 PM
