V9 on Windows 10
David Bearss
Is it possible?
I have some old projects I want to access and archive.
David Bearss
Archicad 18/Windows 11
Alienware 17 R5
i7 2.4 GHz / 16 GB ram
5 REPLIES 5
Eduardo Rolon
Check here:
http://www.graphisoft.com/downloads/fileconverter.html
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
David Bearss
Great thanks, I am glad I do not have to back and do this in XP.
David Bearss
Alienware 17 R5
David Bearss
Been trying to figure out how to use this. Copied v10 into program directory. Then what do I do? There are absolutely no instructions. Launching v10 I instantly get a bug reporter. I have v11 installed and now when launching that I get bug reporter. Any instructions anywhere?
thanks.
David Bearss
Alienware 17 R5
Eduardo Rolon
Not a current windows user so I cannot give a specific answer but as a guess it could be a Java issue.
AC27 US/INT -> AC08
another Moderator
Seems it might be a Quicktime issue.
You need to have Quicktime installed as well.
If you don't have the 17 installation files (where you will find the Quicktime installer), I am sure it is just a Google search away.
