Vectorial Fill Patterns - no patterns available
ngoldie
I go into Options>Element Attributes>Fill Types, and the only Vectorial Fill option I have available is Drawing Title Block. Am I supposed to import these from somewhere?
I just want a basic grid pattern..
Cheers
Naomi
Archicad 20
MacBook Pro - laptop
David Maudlin
Naomi:
You can import Fills from another project using the Attribute Manager. Once Attribute Manager is open, you can open a template file (Applications > GRAPHISOFT > ARCHICAD 20 > Defaults > ARCHICAD > template files) and import as many Fills as you need. Another option is to open a template file in a new instance of ArchiCAD and copy and paste the Fills from the template file into your current project file.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
ngoldie
That worked, thanks!!
Archicad 20
David Maudlin
Great, thanks for posting back.
