2010-02-21 11:56 PM - last edited on 2023-05-23 02:58 PM by Rubia Torres
2010-02-24 09:42 PM
2010-02-24 10:05 PM
"Eric Bobrow" wrote:
Steve -…
“Regarding your comments about using the magic wand to automatically trace the exterior - this sometimes works very well, but I often find that it breaks up walls on either side of windows or doors, or continues walls from exterior to interior, or makes other "mistakes" because of the way it interprets the sequence of lines. It may work in some contexts, but not others, and often requires extensive cleanup. Drawing the outline manually allows me to judge when the wall continues and when it doesn't, and requires less cleanup.”
Sometimes you can trace the walls faster than you can find an appropriate set of lines from the foundation plan or somewhere, add or edit some lines, consolidate, paste into a fresh plan, and then use the magic wand to convert it into 3d. It depends on the project and how the original .dwg was made.
However, the floor plan is not a very good place to get the lines you would convert with the magic wand into exterior walls, and the floor plan is not a very good place to start modeling when you already have a complete set of 2d working drawings.
If you let the actual construction process be your guide for how to create the model it will automatically generate a great many efficiencies in the process of conversion. Problems such as you have listed above with using the magic wand on a broken up set of lines is not because the technique is inefficient, it is because you are trying to use the wrong set of lines at the wrong time.
Also, if you follow the “model it as you would construct it” process, you will be able to generate from your own precision model, more and more of what you need as you go along. You will be using your model as the trace reference more than the .dwg.
The fundamental process of converting a 2d .dwg plan to an ArchiCAD BIM should not be based on a strategy of re-drawing everything.. We have tools for converting things faster and better (sometimes) than they can be re-drawn.
Use the Consolidation Tools, Quick Layers, Gravity Tool, Profiler, Magic Wand, Align, Favorites, etc… ArchiCAD has a great set of tools for converting a 2d .dwg plan into a completely functional ArchiCAD BIM. I did not see even one of these very powerful tools used in the video. This is because the process being used has no need for them. This makes my point very well.
Redrawing the walls on top of Trace Reference is only one aspect of how to make a plan to model conversion. In the next video, show off some of ArchiCAD’s more powerful and time saving tools.
Also, reconsider the final objective of the video. In the end, this video demonstrates how to re-draw over things to make a useless model of the shell.
“There is a LOT more to a good template than you can achieve by copying and pasting.”
Like what? And how much time does it actually save over tweaking or importing some configuration on the fly? Name one thing and I will be impressed.
2010-02-24 10:34 PM
2010-02-24 10:59 PM
2010-02-25 01:17 AM
